Intermittent No Start in Warm Weather...04
Old May 14, 2016 | 07:06 PM
Best4x4's Avatar
Dunno about the life of it, I was just using the link as an example.
It could be starter related as well, but normally on a LR if I have a no start or a weak start it's the starter cables, or dirty connections. I've only replaced one LR starter out of all the LR's I've owned and it was full of mud/rust.
Old May 14, 2016 | 07:30 PM
disc oh no's Avatar
I would check to see if you have power on the solenoid control wire (small wire) on the starter when it fails to crank. I'm not sure, but there is probably a fuse for just that wire. You could start by testing there because it will be much easier to get to. If you have power there, then check at the starter connection. If you don't have power anywhere, it's more than likely the ignition switch.
Old May 14, 2016 | 08:34 PM
mln01's Avatar
Crankshaft. Position. Sensor.
Old May 14, 2016 | 11:10 PM
The_OGCJR's Avatar
I think I'm going to start with the cheaper part (relay) by just swapping it out and then go from there.
Old May 15, 2016 | 09:01 AM
Best4x4's Avatar
CKPS is 65.00, and the starter is 99.00 at Auto Zone. You can test the starter on/off the D2.
When I had a CKPS go out the engine turned over fine, but wouldn't fire so I'm still leaning towards the starter related or ignition switch as you say it doesn't turn over at all.
Old May 15, 2016 | 02:59 PM
disc oh no's Avatar
Best4x4 is right. The engine will crank normally with a bad cps. Your problem is in the starter circuit.
Old May 16, 2016 | 05:56 AM
mln01's Avatar
I went back and re-read this thread. One question I have is about the use of the term "turn over." It is sometimes used differently by different people on this forum. If you turn the key to the Start position and nothing happens then it is not the CKPS as I suggested earlier. If you turn the key to the Start position and you can hear the engine "turning over," that is the crankshaft is being turned by the starter motor, then it is likely the CKPS. One other outcome is that you may hear the solenoid clicking but the starter itself does not engage. Any sign of that?
Others have talked about the battery connections, but what about the connections on the starter motor itself. You could perhaps try removing the big cable attached to the starter and use a little emery paper or sandpaper to clean up that connection. Same for the other connectors attached to the starter.
Old May 28, 2016 | 10:48 AM
The_OGCJR's Avatar
When I say engine doesn't turn over I mean, I turn the key and nothing happens at all. Not solenoid noise either.
Being that it only happens in warm weather and has been happening for a couple years would tell me its not a connection issue. Besides, I did check all connections.
I haven't bought the relay yet, but I'm going to do that first.
zeblitz
Aug 6, 2014 03:32 AM
Buzzthrust
Apr 4, 2008 02:56 PM
maxellfullmoon
Mar 19, 2008 11:06 PM
Darover
Aug 28, 2007 03:01 PM
riemer
Jan 27, 2007 12:42 PM
