Intermittent radio
Old Aug 18, 2013 | 08:04 AM
Rodsram's Avatar
Default Intermittent radio
Hi all,
Question to the forum.
While driving home from The Shop in ATL. I was listening to the radio and it would play for about half an hour then stop.
The display would be normal, showing the radio station etc, just no sound at all.
Shut the unit off for about an hour and it would play as usual.(continue driving)
About half an hour and the symptoms return - radio on, display normal, just no sound.
Have read that the radio will play when key is removed for about 20 min', - don't know. If this is related.
Thanks in advance.
Rod
PS. Standard radio 2002 SE.
Old Aug 18, 2013 | 10:16 AM
Would check fuses 16, 20, 26, and 33 carefully for hair line crack or such. This model has the amp inside the radio, so easy to swap whole thing. There is a small amp for the antenna that is above the back glasses. So if you losts stations, but not really stong local stations or other audio functions, that might be suspect.
Old Aug 19, 2013 | 06:27 AM
Rodsram's Avatar
Thank you, will check those fuses.
Old Aug 19, 2013 | 07:13 AM
If out in the radio desert between the Grand Strand and the land of Coca Cola and North Avenue Trade School, the antenna amp going in/out could remove all signal, I'm not sure if some hiss or static would remain. Of course in the evening you could listen to the Braves on WSB AM the whole way.
Old Aug 19, 2013 | 04:36 PM
Rodsram's Avatar
Thanks Savannah,
Unfortunately goes completely silent.
Old Aug 19, 2013 | 05:38 PM
Dismantlers like Paul Grant on this forum can sell you the same unit for a modest fee.
me6067
Jan 18, 2015 06:38 PM
TripleThreat
Feb 20, 2014 10:36 AM
shellshocked
LR2
Jul 2, 2013 09:55 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
