Item found in oil pan
Old Jan 12, 2026 | 09:24 PM
bdruhan's Avatar
Default Item found in oil pan
I am replacing the oil pan gasket on my 2003 Disco II and found a small metallic ring in the oil pan. It measures about 8.5mm in diameter, 4.5mm high, and maybe 1mm thick in the middle...one end has a uniform sloped inside edge and the other has a slightly rounded inside edge. I thought perhaps it was some kind of cap for the dip stick tube but it doesn't fit over the end of it. Any thoughts on what it could be? Pictures attached.
Old Jan 12, 2026 | 09:46 PM
Best4x4's Avatar
VC Gasket spacer
Old Jan 12, 2026 | 09:50 PM
bdruhan's Avatar
Thanks!
AndrewDF
May 7, 2024 02:40 AM
cvhyatt
Jan 14, 2022 07:55 PM
Edge77
Oct 29, 2021 05:52 PM
Fast951
Apr 12, 2015 10:00 PM
chargersfan
Aug 25, 2007 12:22 PM
