Its burping
Old Jan 7, 2009 | 10:48 AM
targotsi's Avatar
Default Its burping
95 Disco I with about 150k on her. As of late she has been having belch like back fires when reaccelerating after coming to a stop. Won't necessarily do it at first start however. Also seems to be running a little sluggish and may be misfiring on occasion. Any ideas? I thought i would try to clean the injectors but knew i should check with you guys first. Thanks for the help
Old Jan 7, 2009 | 11:06 AM
Default RE: Its burping
Possible carbon issue and even more so a possible burned valve. Might want to do a compression test to verify which cylinder may be causing the problem.
Old Jan 7, 2009 | 11:14 AM
targotsi's Avatar
Burned valve doesn't sound good, expensive fix? If so anyone want a 95 Disco at a reasonable price?
Old Jan 7, 2009 | 06:58 PM
Start by having your timing adjusted. You have a distribitor and they need to be readjusted once in awhile.
You will need a old mechanic, one with no hair and few teeth, only a well seasoned mechanic will know how to do this, the young guys fresh from school wont have a clue.
Externet
May 5, 2015 04:10 PM
jamestfl
Mar 11, 2014 01:36 AM
b c
Aug 6, 2013 12:49 AM
kenjisnocon
Jun 16, 2009 06:28 PM
llPANCHOll
Feb 26, 2009 07:32 AM
