Jack Stands
Old Apr 22, 2015 | 08:35 PM
drowssap's Avatar
If you're going with a bottle jack just throw the stands under the frame rail
Old Apr 23, 2015 | 08:24 AM
acamato's Avatar
When I did my lift, I put jack stands under the frame. I did not have to disconnect the cross member or swaybar. I recall using the bottle jack to push the front axle down.
Here is an overview og installing a lift, that wreckdiver1321 posted to his blog. You can see where he put the jack stands.
The Disco: Suspension ? Part One | Montana Overland
Old Apr 23, 2015 | 08:26 AM
acamato's Avatar
Originally Posted by Alex_M
I'm going to throw a crazy idea out that probably has no chance of working. What if you disconnected all sway bars, removed the front cross member, got the suspension completely flexed out, and then put the bottle jack between the axle and bump stop. Ok, now someone come tell me how if I try this I'm going to kill myself.
Creating more work than needed. I did not have to disconnect the swaybay (maybe because I have ACE) or remove the cross member. I did use a bottle jack to push the axle down.
Old Apr 23, 2015 | 11:19 AM
Alex_M's Avatar
Hmm. Yea, I just don't have a good way to get it up off the ground. I've only got one bottle jack and 2 jack stands. I really need a better jack.
Old Apr 23, 2015 | 11:42 AM
drowssap's Avatar
you could use a spring compressor, they can be borrowed, rented.
use your jack to place the stands under your diff. unbolt the two bolts on the bottom of the shock and the four bolts holding the shock tower, raise the shock tower out with the shock attached. insert the spring compressor, tighten and slide the coil out threw the wheel opening. the same thing in reverse to install.
nicksims
Dec 24, 2012 10:45 PM
30more
Nov 3, 2012 10:08 PM
catchthebig1
Aug 7, 2010 07:32 PM
Prepilot_3ck
Aug 26, 2009 12:34 PM
Street Wolf
Nov 20, 2008 01:13 PM
