Sponsored by: CARiD
Jack stands- where to place?
Old Dec 23, 2012 | 06:02 PM
nicksims's Avatar
7th Gear
Default Jack stands- where to place?
I'm about to pull the starter and I have the jack stands. Wheels chocked. Parking brake set. I'm about to jack up the front passenger side, place the stand, then jack the driver's side, and place. But exactly where? I only have the original jack and am using the jacking points suggested in the manual. But should I use the axle points as the RAVE suggests? It looks like that would be done if I jacked up the whole front end at once instead of one side at a time.
I've been searching and haven't come up with the answer yet.
Thanks for help with what I think is a simple thing. I just don't want the stands in the wrong place!
-Nick
2001 Discovery Series II, 125,000 miles with no modifications (yet!)
Old Dec 24, 2012 | 10:27 AM
Rovin4life's Avatar
you can set them on the frame or the wheels. but you don't need to pull the wheels just get in and get the starter bolts out.
Old Dec 24, 2012 | 10:46 AM
lr2001silver's Avatar
Banned
Also never rely on that jack it can fail leading you to be crushed.
Old Dec 24, 2012 | 11:17 AM
I always put mine either under the axle tubes or the lower shock bracket mount.
Old Dec 24, 2012 | 12:59 PM
robersonb's Avatar
At least its tall enough to help some if it fails. I had mine jacked up and was underneath it when a small earthquake hit here in East TN. Everybody was talking about it and all I thought was how freaked out I would have been if it hopped off the jack . I had enough clearance where I was at but I am sure I would have needed a new pair of pants lol.
Old Dec 24, 2012 | 02:19 PM
Rovin4life's Avatar
Thats one reason why I can't understand how you survive in california in this business. Having cars fall on you when an earthquake happens.
Old Dec 24, 2012 | 05:08 PM
nicksims's Avatar
7th Gear
Thanks for your responses. I went with the axle. Luckily I have a neighbor with the 3 ton jack hydraulic jack and I'm using 3 ton jack stands. A related question- Where exactly is the correct place to use this? I read in the Workshop Manual-
" Position cup of hydraulic arm under differential casing (1).The differential casing is not central to the axle. Care should be taken when raising the front road wheels off the ground as the rear axle has less sway stiffness."
I haven't done this yet, but is it really ok to raise this high enough to place the jack stands? I do have both rear wheels chocked. But as I'll be lifting off center, won't it be unsteady? Thanks again, and Ho! Ho! Ho!
Old Dec 24, 2012 | 06:12 PM
fishEH's Avatar
You're really overthinking this. I usually encourage people to DIY but if you're having this much trouble with lifting up the truck(which isn't needed) I can't imagine you'll have much luck replacing the starter. I'm not trying to be a jerk but some people just aren't mechanically inclined. If you're just looking for room to maneuver under the truck just buy some ramps and drive on.
For tips on replacing your starter search for "starter". And D2's and D1's use the same starter.
Old Dec 24, 2012 | 06:40 PM
nicksims's Avatar
7th Gear
I assumed I was overthinking, but better to ask while I had the chance. I just need it raised slightly to maneuver underneath. And if I could start this to get it up the ramps, I would have!
Thanks.
Old Dec 24, 2012 | 10:45 PM
fishEH's Avatar
Ahhh yeah, being able to drive the truck up the ramps would help I guess. LOL. Jack up one side from under the radius arm, place the jack stand under the axle. Repeat on the other side.
That's one benefit of having a lifted truck. No need for ramps to work under the truck.
LRlax11
Apr 23, 2015 11:42 AM
30more
Nov 3, 2012 10:08 PM
catchthebig1
Aug 7, 2010 07:32 PM
nashville rookie
Mar 18, 2009 06:34 PM
Street Wolf
Nov 20, 2008 01:13 PM
