Jimmy the Driver's side window
You can wedge it from the inside using a couple of small leveling shims from the cabinet section of a hardware store, inserted down between the window and the inner felt seal. Or, if you want something a little less ghetto looking, you can pop the door card and cut a piece of 1X2 to length to support the bottom edge of the window against the bottom (or "floor") of the door.
Best of luck!
Best of luck!
Str8BacardiL
03-18-2006 10:57 AM
