Jumped off truck and did - to + . I already knowi a
Old Dec 1, 2017 | 04:03 PM
Frank4's Avatar
Originally Posted by dgi 07
had someone do this to a late 2000's S Class. First $10k estimate I ever submitted to a customer. Guy paid it too, guessed he really loved that car.
Edit. Melted harness. if you have a scan tool, hook it up and see codes what it kicks back
Haha, oh man I hope that's not me. I have done some serious knuckle bashing on this thing for the last 8 years. I really hope I haven't done her in with such a stupid mistake.
The codes that I get are P0327, which was there before and P0560. The P0560 is low voltage.
Old Dec 1, 2017 | 04:13 PM
OverRover's Avatar
It's very possible you didn't cook the computer. As LB suggested take both leads off the battery and get it on a charger.
Which car needed the jump, your LR or the other car? I hope it was yours because the computer could still/now be reading the P0560 code due to a weak battery.
Ok , odd question but what does the alternator smell like? Any cooked electrical/diode smell?
Old Dec 1, 2017 | 04:28 PM
Frank4's Avatar
Let's hope so. It was my Land Rover that needed the jump. The car that provided the juice was my company car, it's 100% fine. I didn't notice a smell from the alternator but I'll check. The code is still there but the battery is at 11.67 just sitting in the truck.
Old Dec 1, 2017 | 04:48 PM
dtmbinb's Avatar
I'd say it's time for a new battery.
Old Dec 1, 2017 | 04:52 PM
aemnky606's Avatar
I have had a battery show a good charge but be bad. I would pull it take it to the local auto parts store and have it tested.
Old Dec 1, 2017 | 05:07 PM
emncfi's Avatar
I did this on my 3000gt VR4 and ended up melting a really big fuse, but nothing else, and yes it would not start with that melted, lots of people have probably done it, but its one you only do once
Old Dec 1, 2017 | 05:51 PM
Frank4's Avatar
Battery is less than 1.5 Old. And won’t it still start with a bad battery that is being jumped from a strong one. I mean I could stay on the ingition forever, it turns over but never starts running.
Old Dec 1, 2017 | 06:08 PM
Best4x4's Avatar
Anything under 12v = needs replacing. If the vehicle is running 13.4v & up. Engine off 12.1 would be the lowest I'd trust as it really shouldn't drop below 12.5v with the engine off. 11.6 is on the low side if you ask me.
Old Dec 1, 2017 | 06:27 PM
OverRover's Avatar
So no alternator stink then.
And IDK what fuses etc you have checked but just for giggles look at;
Engine Fuse Box: Remove Relay R9, look at/smell the contacts of the relay and box. Also check Relay R1. Give them both a lite thump with your finger in case a contact is stuck.
And Check Fuses F1=30amp, F10=30 amp, F12=20amp, F13=10amps And Check FL8=50amp
Passenger Fuse Box: Check F23, F24, F29 all 10amp, and F34=30amp.
And a longshot, pull a plug to see if they are fuel soaked.
The battery volts are low, but can you load test the battery where you are now?
Old Dec 1, 2017 | 06:57 PM
Frank4's Avatar
I pulled the battery and had it tested, machine said it was good but needed a charge. Doing that now. I don’t want to get off track on the battery, if this thing had a bad battery and it is being jumped off it would still start. I checked all the fuses under the hood and under the steering wheel, everything looks good there.
