Jumped off truck and did - to + . I already knowi a
Old Dec 4, 2017 | 07:59 PM
  #41
OverRover's Avatar
Originally Posted by Motorhead1
Buy the Rover titZ???
OMG you SUCK I almost spilled my coffee laughing!!!!
Old Dec 4, 2017 | 09:42 PM
  #42
Frank4's Avatar
I already bought her a huge Safety Devices RACK, does that count!?
Old Dec 5, 2017 | 05:02 AM
  #43
OffroadFrance's Avatar
Originally Posted by Frank4
Ok, this takes a lot for me to admit but I screwed up the easiest and most common procedure besides filling the tank. I was in a hurry and hooked + to - when trying to jump off, it took me a few seconds to realize it a after I saw more sparks than usual at the running vehicles + post. I immediately removed the cables and hooked them up the right way. So to be clear I didn't try to crank the Land Rover with the cables hooked up - to +.
Now with the cables hooked up correctly it turns over but no start. I am getting two codes, one was there previously (P0327 knock sensor) and the new one is P0560- system voltage.
I reset the inertia switch and still no start.
Can anyone offer any insight here? Anyone brave enough to admit that they have done this and how they fixed it?
Thanks!
Ya silly boy Frank, you won't do that again in a hurry eh.
Frank, try all the ideas the guys have already mentioned first but unfortunately the battery polarity reversal normally 'cooks' the engine ECU at minimum, maybe some others.
Good luck with your endeavours and hope you sort it out cheaply.
Old Dec 5, 2017 | 05:10 AM
  #44
" Funny how no one has mentioned the alternator yet."
I remember doing that back in Post #12, I must be writing in Chinese.
And YES you can have the alternator benched tested. It's a very simple process any Napa, AutoZone, etc can do for you for free. Remind them to be sure they put the belt on tight.
RE: Post #19. You mentioned checking fuses, but did you remove/check the relays R9 and R1 PLUS the condition of the fuse box contacts below?
"Engine Fuse Box: Remove Relay R9, look at/smell the contacts of the relay and box. Also check Relay R1. Give them both a lite thump with your finger in case a contact is stuck."
You are right, it could be, I did consider the alternator rectifier pack also and also measure the battery output for voltage and amps (amps needs a resistance drop tester).
Old Dec 5, 2017 | 07:02 AM
  #45
Lisa Bunch's Avatar
Diamonds are a girls best friend, so buy her some bling - LED lights!
Old Dec 5, 2017 | 10:14 AM
  #46
Would that make a light bar a "Diamond Choker"?
Old Dec 5, 2017 | 11:42 AM
  #47
Motorhead1's Avatar
I think Frank already refers to his rover as a gold digger...Rovers are like hot chicks....High maintenance.
Old Dec 5, 2017 | 04:42 PM
  #48
Frank4's Avatar
Little late to the party, it's all taken care of. Thanks though.
Old Dec 6, 2017 | 09:37 AM
  #49
dgi 07's Avatar
Glad you figured it out without having to replace anything major!
DiscoUSA
Apr 24, 2017 10:28 PM
The Deputy
Nov 27, 2016 05:16 PM
JuniperSprouts
May 1, 2015 03:59 PM
pottzie
Jul 25, 2012 09:24 PM
P38_Ireland
Aug 13, 2010 02:37 PM
