key broke off in ignition, light is red?
The key is not broken, the remote came off is all.
This is what the key looks like.
Key With Remote Functions | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
The super glue trick works if done right.
On a side note, your cruise not working is most likely a bad vacuum line, no biggy.
Engine knock on hard acceleration, are you using premium gas? Premium is required if you didnt already know.
The transmission temp sensor is bad, replace it (assuming the trans fluid is full and in good shape)
The seat not working is probably a bad seat switch.
Craig's List and junk yards are your friend.
www.rovahfarm.com
www.atlanticbritish.com
www.google.com
www.rovahfarm.com
www.google.com
