Key Cylinder is TOUGH
#21
Okay here is the basics with "graphite" it was used back in the day when there wasn't Tri-Flow, WD40, or any other lubricants. Back then locks got old & worn out & graphite was used to fill the gaps of the old locks and to lube it....
It is a "snake oil" for locks of today and it does more harm than good. Those auto store chains also sell fake hood scoops which do absolutely nothing....
#22
DIY......Tube of graphite on your surface of choice spread thinly and exposed to a humid environment for a period of time should produce your glob. May want to add a bit of lube to reproduce real lock world.
#23
I'm in the financial institution business (CCTV, Alarm, Access Control, Locks, RTS, ATM, Vault) and the last thing we'd ever use is Graphite Spray. Tri-Flow is what we mainly use on FI locks.
On a LR ignition switch Tri-Flow would be my #1 choice, but since it can be kinda hard to find depending on your location any lube used lightly on just the key (then rake it in out) should do the trick.
