Key Cylinder is TOUGH
Old Aug 17, 2017 | 11:35 AM
  #21
No Doubt's Avatar
Talking
Originally Posted by Best4x4
Okay here is the basics with "graphite" it was used back in the day when there wasn't Tri-Flow, WD40, or any other lubricants. Back then locks got old & worn out & graphite was used to fill the gaps of the old locks and to lube it....
It is a "snake oil" for locks of today and it does more harm than good. Those auto store chains also sell fake hood scoops which do absolutely nothing....
Ha! Fair point. Now can someone show me a glob of graphite+moisture?
Old Aug 17, 2017 | 07:31 PM
  #22
number9's Avatar
DIY......Tube of graphite on your surface of choice spread thinly and exposed to a humid environment for a period of time should produce your glob. May want to add a bit of lube to reproduce real lock world.
Old Oct 3, 2017 | 12:14 PM
  #23
mln01's Avatar
I'm in the financial institution business (CCTV, Alarm, Access Control, Locks, RTS, ATM, Vault) and the last thing we'd ever use is Graphite Spray. Tri-Flow is what we mainly use on FI locks.
On a LR ignition switch Tri-Flow would be my #1 choice, but since it can be kinda hard to find depending on your location any lube used lightly on just the key (then rake it in out) should do the trick.
I'll be rebuilding the door lock on my truck this weekend. I plan to use the CRC aerosol silicone lube I have on hand. Tri-Flow, which is PTFE-based (Teflon), looks interesting but I have a lot of different lube products in the garage already.
Old Oct 3, 2017 | 05:51 PM
  #24
OffroadFrance's Avatar
Originally Posted by KingKoopa
Silicone spray should work as well. Wonder why lock smiths don't like graphite, it's awesome?
I love silicone spray, the lube for most things that are stuck. Graphite spray is great also.
Old Oct 3, 2017 | 08:00 PM
  #25
matt3502's Avatar
That is not a hood scoop it was a pre- hurricane periscope installation!
If I'm wrong then it's "paddle faster! I hear Banjo music time!"
Old Oct 10, 2019 | 12:06 PM
  #26
Ben Matheson's Avatar
I have a similar problem but it feels like a tremendous spring pressure preventing the key from pushing in...
Ben Matheson
Aug 22, 2018 10:39 PM
ebindustries
Oct 28, 2017 11:57 AM
elpapisf
Apr 18, 2012 06:19 PM
northon11
Jan 11, 2010 09:16 AM
cryptic
Dec 6, 2007 02:32 PM
