What is this 'mod'?
Old Apr 29, 2022 | 02:20 PM
simscrim's Avatar
6th Gear
Default What is this 'mod'?
Anyone know what this is? New to me 2000 Disco II, with this handle in the center console. Previous owner also did not know.
Thanks!
Old May 1, 2022 | 05:45 PM
The Deputy's Avatar
A very creative CDL locking mechanism. Looks lIke they used an old wiper blade arm.
Old May 25, 2022 | 12:07 PM
simscrim's Avatar
6th Gear
Thanks for the reply.
How is this activated? I seem to be forcing it, to no avail? Under the liner, there is a cut that allows it to move to the left (about a cm), and then upwards/downwards (about a cm).
Old May 25, 2022 | 01:39 PM
greisinb's Avatar
It should be able to turn, but not a lot. Its going down through the center console to a nut on the transfer case enabling it to lock. You can see it from under the truck.
Old May 27, 2022 | 01:18 PM
WaltNYC's Avatar
That is "redneck AF" but I have to say, I like the radial arrangement better than the lever.
Old May 28, 2022 | 01:50 AM
JohnZo's Avatar
CAUTION: Need to be sure not to engage the CDL on pavement driving. It is only for dirt or snow, otherwise could cause drive train damage.
CDL is engaged while in slow motion (less than around 5 mph) so the gears can line up. Think of it as the fun lever for off road! Might also be able to shift to lower gear range.
Old May 28, 2022 | 05:03 AM
mln01's Avatar
There's a writeup over on DiscoWeb about how to fabricate a lever like this to operate the CDL on the "99 - '02 trucks that shipped with transfer cases that had the CDL feature but no shifter to enable it. There's nothing wrong with the method, although the wiper arm lever isn't as attractive as other examples.
A5scott
May 28, 2019 07:23 PM
housedj
Oct 15, 2006 11:22 AM
deepessions
Sep 5, 2006 08:44 PM
CronicJoeBlunt
May 19, 2006 10:48 PM
mikemeyer0
Apr 15, 2005 05:42 PM
