Key FOB repair
Old Apr 24, 2017 | 10:35 AM
zuke's Avatar
Default Key FOB repair
My key FOB would lock but not unlock. I pulled it apart and found one of the two micro-switches was broken. It is the rectangle in the lower center.
So on ebay I was able to find this:
2x NEW SWITCH BUTTON REMOTE KEY FOB LAND ROVER DISCOVERY 2 DISCO HSE TD5 LR | eBay
$7 plus $2 shipping I thought I would give it a try. It looks like a pain to resolder but nothing to lose.
Has anybody tried this?
Old Apr 24, 2017 | 11:54 AM
Luckyjayb's Avatar
Yea I did it but it was a pia with that small button and getting it all lined up but it worked
Old Apr 24, 2017 | 02:33 PM
Best4x4's Avatar
I've repaired 2 D2 keys by replacing the little micro-switches. I was able to hold down the new micro-switch with a zip tie wrapped around the circuit board and another zip tie wrapped around the upper part (just above the button) of the zip tie with it's head aiming (tail cut off clean) down to put pressure onto my new switch enough for me to get one tab soldered on good enough to hold it into place.
The 8.00 kit I got from China was excellent quality and had a perfect copy (down to the p/n on the back & the LR logo on the front). You can not tell the difference between it it the one from the Dealer.
One of my circuit boards was a corrosion disaster but after cleaning it with contact cleaner and using a very soft toothbrush I was able to repair it, and use it. It doesn't have a lot of range on it, but I could care less as I only open the doors once I'm close to my vehicle anyways.
Old Apr 24, 2017 | 04:21 PM
Friday Night Disco's Avatar
I have done this as well, my solder job was crappy and if you can invest in a fine tip solder iron it would make you life easier.
I used some needle nose pliers to hold mine in place as a soldered it connections.
Old Apr 24, 2017 | 04:22 PM
earlyrover's Avatar
Default circuit board sholdering of micro switches
[QUOTE=zuke;604115]My key FOB would lock but not unlock. I pulled it apart and found one of the two micro-switches was broken. It is the rectangle in the lower center.
HINTS:
USE CARE IN SOLDERING ON PRINTED CIRCUIT BOARDS, USING AS LITTLE HEAT AS NEEDED (A LOW WATTAGE SOLDERING IRON IS NEEDED), TO GET THE JOB DONE, OR RISK DAMAGE TO THE BOARD FROM EXCESS HEAT. BEST DONE UNDER MAGNIFICATION, JUST HEAT ENOUGH TO REMOVE EACH LEG OF THE BAD SWITCH TO REMOVE IT, OR BETTER YET, CUT EACH LEG OFF THE OLD SWITCH TO REMOVE IT, AND JUST ENOUGH HEAT, NO MORE, TO SOLDER IN THE NEW ONE. IF YOU ADD ANY SOLDER, USE ONLY ROSIN CORE FINE WIRE SOLDER (RADIO SHACK TYPE IS GOOD), NEVER EVER USE ACID CORE, SOLDER OR YOUR BOARD WILL EVENTUALLY BE JUNK. BEFORE POWERING IT UP, LOOK THE BOARD OVER UNDER MAGNIFICATION, TO BE SURE YOU HAVE NO SOLDER WHERE IT SHOULDN'T BE, SHORTING SOLDER TRAILS. IF YOU ARE NOT GOOD AT DOING SUCH MINUTE CAREFUL PRECISION WORK, FIND SOMEONE ELSE TO DO IT FOR YOU, OR YOU MAY BE SORRY-----
jycsalas
Feb 2, 2019 04:46 PM
RicketyTick
Jul 18, 2014 11:00 PM
pilsner
Apr 7, 2008 03:24 PM
Jay
Apr 27, 2005 03:49 PM
