Key and Fob Upgrade Pictures
Old Apr 25, 2013 | 12:18 PM
  #31
cosmiccharlie's Avatar
Originally Posted by MC04DII
Hmm, they both show separate blank keys though. I think it may be the same. Grammar is not the best, obviously. To everyone who has gotten the first one, does it come with a blank key, and has anyone tried to swap the original key into it? Thanks.
It comes with a blank key. You cannot swap an original key blade on to it.
MC04DII, I took mine to a local locksmith here in Homewood and he screwed it up. But I am pretty positive Alabama Lock and Key on Greensprings could cut it. I haven't ordered another one yet, but plan to soon.
Old Apr 25, 2013 | 12:24 PM
  #32
Originally Posted by ZGPhoto
Counter clockwise apparently, clockwise makes the key want to stay in. Got it, thank you! Sounds like the chip is moving around in there though, anyone else have this issue?
I had the same issue with mine. I took a thin piece of foam and put between the battery and the back case half and cured that problem.
Old Apr 25, 2013 | 12:34 PM
  #33
IMTIM8ER's Avatar
7th Gear
Where did you get the flip key from.
Old Apr 25, 2013 | 12:40 PM
  #34
jthomas's Avatar
Really............................Really? LMAO.
All kidding aside, a company based in Italy sells them on craigslist. Click HERE to go to the site to buy it.
Old Apr 25, 2013 | 12:43 PM
  #35
China
Old Apr 25, 2013 | 12:47 PM
  #36
ZGPhoto's Avatar
Read page 2 or something!
Old Apr 25, 2013 | 01:03 PM
  #37
rappo999's Avatar
Default Getting Keys Cut
I have had the "pleasure" of getting 2 Disco-2 keys cut in the past month. Lowes, Home Depot, WalMart and Pep Boys all use the same modular key cutting machine. They do not work with our keys - even though there is one that is close.
I have had to go to an ACE hardware store and get the key-guru to get it to almost work. The blank that works is ilco X239 RV4. The guy will complain that the key jumps around. If he is good, it will almost work.
You then have to go home and get out your metal files and file the pointy tip down a bit and touch up the rest of the key. I have done it twice now - both keys work now... Kiind of annoying but I learned something about key making.
Old Apr 25, 2013 | 01:41 PM
  #38
Can'tgetright's Avatar
7th Gear
So is it safe to assume Land Rover WON'T cut them or is it just an exorbitent fee?
Old Apr 25, 2013 | 01:58 PM
  #39
Street Wolf's Avatar
I would like to help on suggestions of where to get the key cut, but I'm about to leave right now and go get it done at a Lock&Key place that is only located local to me.
I would suggest finding someone local to you as well who specializes in lock and key sort of things. I'd be huge pain in the *** for someone to screw it up and then you have to wait for another keyfob to arrive from China again. :I
Old Apr 25, 2013 | 01:59 PM
  #40
Just a hunch here, but I doubt a Land Rover dealer would touch it since it's not a factory key/fob setup, and if they did... no doubting it would be far to expensive.
