Knock sensor
Old Sep 13, 2012 | 03:31 PM
Kena's Avatar
4th Gear
Default Knock sensor
First off i'd like to mention the help this forum has given me troubleshooting my disco. Here's a brief background, Bought my wife a 01 disco SE7 new in 3/01. After about 56K miles she ran over something on the fwy and put a huge hole in the pan..emptying all the oil and subsequently blowing the engine. Good news was that AAA covered the new motor expense!. Cut to march of this year and she rear ends someone and insurance totals the car. I buy it back for 1200 and buy a blown motor donor vehicle and do all the necessary work. It has 110k miles on the chassis now and about 53K on the motor. Thanks to the forum I got rid of the 3 amigos ( which i've lived with for 3 years!) put a 180 soft spring thermostat and added a ultragauge. Amazing how inaccurate the stock gauge is. Temps now never go above 208 and they used to hover in the 218-221. Grat mod for $50!
My question is this, I have a P0327 code ( left knock sensor) so I replaced the sensor and still get the code on the ultragauge. I unplugged the sensor and no change. How can I trace where the wires go from the sensor. I looked in the RAve but im not quite clear. One of the wires coming out of the sensor looks like it is attached to the main lead about 6" up. Does that sound right?
Any help would be appreciated. Thanks, Ken
Old Sep 13, 2012 | 07:30 PM
Down load a free copy of the Rave CD, shop manual and it will walk you thru it.
Old Mar 8, 2013 | 10:17 AM
caymandrew's Avatar
Hi Kena, I have the exact error code and issue. Did you get it resolved? Any advice? Thanks.
Old Mar 8, 2013 | 10:49 AM
Here's two pages on the sensor. One on each side of block. Plug needs to be clean on the metal contacts, it uses a shielded cable to take the low voltage signal back to the ECU.
File Type: pdf
File Type: pdf
nycdisco85
Sep 5, 2011 10:31 AM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stupid
Nov 23, 2008 01:17 PM
stick
Jan 27, 2008 01:29 PM
