Knock Sensor - Replacement Part Question
Old Feb 24, 2012 | 11:28 AM
  #21
DSCVRY's Avatar
I did not test it specifically. While less expensive than the dealer's version, it visually appears to be the EXACT same sensor as the one it replaced (both Bosch). Perhaps I'll swing by the dealer and get one there just to test it out. I can always return it if that's not the issue I suppose.
Old Mar 3, 2012 | 02:21 PM
  #22
DSCVRY's Avatar
Just wanted to close out the thread. Before I went messing with the harness, I decided to test to make sure the new knock sensor I had put on wasn't faulty. I ordered another from Rock and guess what? All fixed. Turned out that my first replacement sensor WAS faulty. I'll send it back. Now, hopefully no codes will come on until I can get back to the NJ DMV for reinspection.
Thanks everyone for your advice. As you know, this forum is great.
Old Mar 15, 2012 | 11:38 AM
  #23
DSCVRY's Avatar
This thread is back from the dead. So, within 50 miles of my replacing that sensor, I get the code again. After cursing amply (I literally shut off the radio to hear myself curse.), I decided to throw in the towel and take to the dealer.
Turns out that a previous mechanic (prior to my ownership) working on the power steering had ratcheted down a bracket and caught knock sensor wiring behind it. He had ratcheted it so tight that it had impacted the connection, hence the erratic behavior.
Hopefully, this is the end of this thread. And if anyone needs a knock sensor, I have a few handy.
ServerGuy
Apr 3, 2015 07:51 AM
nycdisco85
Sep 5, 2011 10:31 AM
targotsi
Feb 18, 2009 05:58 PM
stupid
Nov 23, 2008 01:17 PM
stick
Jan 27, 2008 01:29 PM
