Knock while in Park
Old May 31, 2013 | 10:55 AM
JT3's Avatar
JT3
4wd High
With the transfer case and differential fluid... recommended fluid?
Old May 31, 2013 | 10:58 AM
JT3's Avatar
JT3
4wd High
Forgot to mention, brake bleed, new pads and rotors, new thermostat, radiator, new heater core, and head gaskets have been done.
Old May 31, 2013 | 11:01 AM
any 85/140, you will need 7 quarts. Was your tranny fluid clear red or brownish when you last checked it?
Old May 31, 2013 | 11:07 AM
JT3's Avatar
JT3
4wd High
Tranny fluid didn't look bad. I did a drain and refill about a month ago.
Old May 31, 2013 | 11:09 AM
JT3's Avatar
JT3
4wd High
Will do the transfer and diff fluids while i have it up on ramps tonight
Old May 31, 2013 | 11:37 AM
Big Jim Swade's Avatar
You might want to remove the inspection cover and see if the flex plate is loose?
Old Jun 2, 2013 | 10:15 AM
jrmdir's Avatar
Wil the truck hold on a hill in Park? I"m not sure about the Disco transmission, but if the parking pawl engages a part that would normally be spinning while at rest the pawl may been sheared off it and might be just touching the rotating part? I know this is a long shot becasue I think the pawl usually engages with the output shaft, which should be stationary at rest. Just a thought.
Old Jun 3, 2013 | 06:41 AM
drowssap's Avatar
did you find the cause of you knock in Park, changing fluids is great and need but I don't think it has anything to do with your knock in park
Old Jun 3, 2013 | 09:40 AM
artstevenson1958's Avatar
I also had the same problem with my 2003 Disco. One of my friends said that it was an "aesthetic" defect in the truck, while I read somewhere in the forums that it could be evidence your oil pump is failing. I have never had any mechanical problems otherwise and have driven 30,000 miles with it before handing it over to its next owner.
Old Jun 3, 2013 | 10:16 AM
drowssap's Avatar
if it were your oil pump it would not make noise in park only.
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
