Labor Times for a Transfer Box swap
Old Dec 16, 2010 | 10:39 AM
ringerso's Avatar
Question Labor Times for a Transfer Box swap
Was wondering if anyone knew the Labor Time to do a Transfer Case swap on a 2003 Disco?
thx,
rich
Old Dec 18, 2010 | 10:43 AM
Why do you ask, who is going to be doing it and are you rebuilding or swapping one out?
Plan on 5 to 6 hours plus depending on what you are doing
Old Dec 18, 2010 | 10:51 AM
ringerso's Avatar
Thanks Mike...Putting a new case into my '03, with locking CDL.
Old Dec 27, 2010 | 04:15 PM
yloDiscoII's Avatar
ringerso - Have you done the swap yet? If yes, how much did it set you back if you don't mind me asking. I am looking to do something similar on my '02 and and weighing my price options. Thanks!
Old Dec 28, 2010 | 05:06 AM
ringerso's Avatar
I haven't done the swap yet. I plan on doing it at the end of January. I purchased a used transfer case from Marty Powell ($100 for the case, and $75 for shipping), along with a used D1 shifter for it ($125). I'll post some results after it's done.
Old Dec 28, 2010 | 08:27 AM
What was this used t/case out of, I hope another 03 or 04 or you will have problems since the earlier t/cases are different.
Old Dec 28, 2010 | 12:12 PM
yloDiscoII's Avatar
Good stuff, sounds like a pretty good deal. I am wanting to do this swap before the summertime as well, just need to convince the wife to authorize funds. If you did a step by step pictoral/how-to, I'd appreciate ithaha. Good luck with your swap....January's right around the corner.
Old Dec 28, 2010 | 12:46 PM
twaszak's Avatar
Default interesting iphone / android app for estimating parts and labor
Hi,
I found this iphone/android application called "RepairPal". It's free and you can download it from the Android Market.
Put in your make and model etc and it lists a whole bunch of repair and service possibilities....
Then put in your zip code and it'll do an estimate of the cost range of parts and labor...
For instance: For Catalytic Converter Replacement in Lynnwood Washington it gave the estimate between $1226 and $4318. (Parts estimate was $1030-$4068 and labor estimate was $196 - $250).
I'm not sure how accurate this program is but I'd be interested to know what DiscoMike and other knowledgable members think of it.
It can be found at http://repairpal.com/mobile (or if you have an android phone go to the Market and do a search for "RepairPal".
Old Dec 28, 2010 | 02:05 PM
antichrist's Avatar
Considering that Repairpal says DII hub bearings are $25-$35 I wouldn't rely on it for much.
The Land Rover published book time for R&R of a transfer gearbox on a D1 is 5.4 hours. Since the D1 and DII are near the same for the gearbox I'd say it's close. Keep in mind that's for a Land Rover shop and mechanics who have likely done it before.
Old Dec 28, 2010 | 06:56 PM
lordmorpheus's Avatar
FWIW Mitchell book time for transfer case R&R on a 2003 Discovery HSE is 7.7 hours.
StormTroopa
Sep 10, 2009 01:06 AM
firstcoast
May 19, 2009 10:42 AM
bmkraus
Oct 6, 2008 09:18 AM
cnsford
May 9, 2008 11:30 AM
ant996
Defender
Sep 14, 2006 05:03 AM
