Land Rover Discovery 2.5 litre (Manual) for towing a speedboat
Old Oct 30, 2014 | 08:15 AM
lellylel's Avatar
5th Gear
Default Land Rover Discovery 2.5 litre (Manual) for towing a speedboat
HI People,
I need help!
I own a
Bombardier Celebrity 220 CC Cuddy Cabin
Mercruiser Engine 5.7LX/V8 Thunderbolt 'V' Ignition Alpha
Dimensions: LOA 6.70m/LWL 5.80m/Beam 2.50m/
Draft Min 0.50m/ Draft Max 0.90m/
Displacement 1,780kg/Headroom 1.60m
I am asking if a Land Rover Discovery 2.5 litre (Manual) would be suitable to tow it.
I also have the trailer Thalmar approx 400 trailer SO: 2,200 - 2,400 (max 2.5 tonne)
Would the Landy be suitable to tow the Boat and trailer from France to Spain.
We have a 4L auto and a 2.5 manual: if both OK (2.5l manage 2.5 tonnes OK), we prefer to take 2.5l manual to Spain (friends used 4litre, an Auto we think, before on it)
Many thanks
Lesley
Old Oct 30, 2014 | 03:04 PM
Alex_M's Avatar
Is the 2.5L the diesel? Shouldn't matter, Disco 2s are rated to pull 7700 lbs. Which is 3500 kilos. You should be fine.
Old Oct 31, 2014 | 12:34 AM
Sir Axlerod's Avatar
(with a v8 in Low Range.... In the Real World, they cap out at at 5300 +-, it's a class 3 hitch and all....)
(would you like a pic from the owners manual? Wife's time... so I have had to find things to read to fall asleep... that manuel will do the trick, if you're curious)
Old Oct 31, 2014 | 05:01 AM
OffroadFrance's Avatar
I've have used a D2 2003 TD5 auto for towing for years and towed large trailers up to a PTAC of 3500kgs at 80mph with no problems at all. The LR D2 TD5 is one of the best tow 'tugs' on the market and will tow a boat withing that range comfortably from France to Spain. After all northern France to southern Spain is less than 1000 miles and we towed 3500kgs regularly 500-600 miles in 12 hours on the autoroutes (motorways) without issues. Autoroute tolls are a different matter though, be prepared for a shock. Hope these links help.
Note: Sitges is in the proximity of Barcelona so easy access from France by autoroutes. No worries towing.
Motorway : key rates 2014 about french motorways - ASFA
French motorway tolls : payment methods - ASFA
Autoroutes.fr le site de l'Association de sociétés françaises d’autoroute*ASFA
Old Nov 3, 2014 | 08:14 AM
lellylel's Avatar
5th Gear
OffroadFrance
Thank you enormously
and agree on tolls
It would not be so bad, if only French alternative was a road that went to 20odd KPH occasionally!
thanks
gargar
May 17, 2011 02:52 AM
d.m.disco
Apr 24, 2010 06:54 PM
Uberwagon
May 21, 2006 12:09 PM
