Land Rover Discovery 2 TD4 TD5 433Mhz Remote Car Key Fob
I’m assuming you mean programming the BCU to accept the Fob code. Inside the fob plastic cover is the PCB which has a code (4 digit IIRC) written on it. You need to plug something like a Nanocom into the OBD2 port and type the code in. Some brands of code readers won’t directly accept the 4 digit code as written, you need a chart that correlates the 4 digit code to a code that does work. I think some members here can get you the chart.
apvargas
Range Rover L405 (Fourth Gen)
Jul 27, 2020 12:54 AM
