Landrover tools?
Old Jan 10, 2012 | 09:15 PM
Texarican's Avatar
Default Landrover tools?
What do you experts do when the rave calls out using LRT-xx-xxx? Specifically, I'm looking at the crankshaft pulley and oil seal. I'm thinking once I dig in I can figure something out without the special tools?
Old Jan 10, 2012 | 09:22 PM
Texarican's Avatar
Never mind. I posted before doing a proper search. Found lots of info
Old Jan 10, 2012 | 09:25 PM
grandkodiak's Avatar
this forum needs facebook type "like" buttons. admins take note
Old Jan 10, 2012 | 09:33 PM
Originally Posted by grandkodiak
this forum needs facebook type "like" buttons. Admins take note
"like"
Old Jan 11, 2012 | 07:19 AM
tee51397's Avatar
SPX Landrover | Main
Old Jan 11, 2012 | 07:39 AM
drowssap's Avatar
thats a good link; but there are no specialty tools need to replace the front seal.
Old Jan 11, 2012 | 08:55 AM
antichrist's Avatar
Why? All that shows is a popularity contest. It has little to do with actual value.
Old Jan 11, 2012 | 11:18 AM
I "like" the post about using some wood screws to screw into the front seal and use them to pull it out. Must say I haven't tried it yet.
Old Jan 11, 2012 | 12:10 PM
tee51397's Avatar
You have to search by legacy part number. Everything has been renumbered since RAVE but they haven't updated the numbers in TOPIx either. If it's a xxxxx/1 and xxxxx/2 tool series you have to leave out the /1 part. Thanks Land Rover!
Also even some of the numbers in RAVE / GTR/TOPIx have been superseded and the only way to know is by tech bulletins. I think the tool you are after, the 12-088 became 12-200 and now is 303-991.
Old Jan 11, 2012 | 08:50 PM
Rovin4life's Avatar
actually if you take the radiator out you could zip the bolt out with an impact gun.
