Larger tires on stock rims with 2 inch lift.
I have a 2003 disco II which I plan on lifting 2 inches.
I want to put on larger tires but I want to keep the stock rims.
My question is, what size tires can i use without causing any problems?
Also is a 2 inch lift too much? not enough?
Just to clarify for the OP. You don't need 4" of lift for a 265/75/16 to fit. It's a 32" tire and popular size on discos with a 2" lift.
When it's time to change out my tires on my '99 w/ a 2" lift, I'll go with 275/65-18 tires. Probably the Nitto Terra Grapplers or the Mud Grapplers. I have Terra Grapplers on it now (stock size), but need to fill up the extra space the lift created.
s10lowrider1994
May 16, 2020 03:41 PM
RoverDude71
Mar 2, 2009 11:03 AM
