Leaf blower up the tailpipe
Old Oct 11, 2018 | 10:34 AM
Ben Matheson's Avatar
Default Leaf blower up the tailpipe
Thinking about blowing air up the tailpipe to find my exhaust leak. Anyone see any problem or issue I'm not thinking of?
Busy weekend coming up. Doing
front shaft
Complete new brakes and rotors
Bleed brakes
Remove headliner
Fix sunroof leaks
Old Oct 11, 2018 | 10:41 AM
Sixpack577's Avatar
Nope, that works good.
Soapy water at every joint or gasket lets you see any leaks too. As opposed to just feeling for air blowing.
Old Oct 11, 2018 | 11:53 AM
ReconDoc83's Avatar
front shaft
Bleed brakes
Remove headliner
Fix sunroof leaks
you can use a smoldering stick or smoking wood pellets with a piece of screen or filter material in front of them; will allow smoke to seep through the leak areas.
Old Oct 11, 2018 | 02:47 PM
MtnCrk's Avatar
I have done it and it worked well. I just set the backpack blower on the ground and stuffed the end up the tailpipe. I just let it idle. dish-washing soap in a spray bottle - spray around the suspected leak locations and it start blowing bubbles
Old Oct 11, 2018 | 03:00 PM
DiscoBuckeye's Avatar
I love this forum! Whoops, did I type that out loud? sorry
Old Oct 11, 2018 | 03:28 PM
mln01's Avatar
I used my shop vac, with the hose on the vacuum exhaust port. Worked great. The hose fit perfectly in the tail pipe and I didn't have to hold a blower in place (notwithstanding MtnCrk's backpack blower idea). I guess it depends on whether or not you have a shop vac and what kind of blower you have.
Old Oct 11, 2018 | 07:23 PM
Extinct's Avatar
Shop vac here, worked great - I could hear/feel the leak.
acamato
Feb 18, 2019 05:42 AM
Slipkid08
May 26, 2018 05:23 PM
jamestfl
Apr 28, 2018 07:32 AM
mirepoixmatt
Aug 27, 2016 08:12 AM
99LRDisc
Apr 26, 2009 06:25 PM
