Leaking coolant 4.0 2002 Disco II
Old Feb 26, 2019 | 10:02 AM
Discoteca's Avatar
Frame is solid - over the last year I have cleaned what was surface rust on the frame and protected with MasterCoat and then undercoating. Pretty much the whole thing is perfect, replaced saggy headliner, fixed little knicks and knacks - replaced leaky power steering pump with hoses, replaced radiator hoses - everything else mechanically is sound except for three amigos but that can be cured.
Looking for recommendations for a shop that can do a good job replacing head gaskets - let me know - I'm digging myself as well.
Old Feb 26, 2019 | 12:01 PM
shanechevelle's Avatar
Ok. I just didnt want to see you put out $2k for a head gasket job only to find out your truck will have to be scrapped.
Old Feb 26, 2019 | 07:04 PM
Discoteca's Avatar
$2000? well, if it's gonna cost me that much for a head gasket job I might just consider turning it into a flower pot or something...
Old Feb 27, 2019 | 05:40 AM
Extinct's Avatar
I have done It about 6 times now, takes me about12 hrs with power tools. Plus there is the parts cost. Doubt you will find a shop to do it for less than $1500
Old Feb 27, 2019 | 08:10 AM
User's Avatar
I’ve done heads for under $150 in around a week with nothing but a kit from LK8, some shop supplies like RTV, and a 180 stat (something I install on every truck I buy, I keep a few around)
I’ve never milled heads. If theyre warped badly I have a friend with a gun shop that can mill.. but again never have needed to and have never regretted it.
in fact I have to do HGs on my 03. Should be fun with SAI. 114,000 miles so I guess it’s time for a 4.6
Old Feb 27, 2019 | 08:18 AM
Discoteca's Avatar
That got me thinking. I've done a lot of work around cars in my lifetime - performed a few head gasket jobs as well. Nothing scares me. Right now I'm in a position that time is really in short supply and therefore I would like someone else to tackle this - but if a push comes to shove, I'll dish out $160.00 for parts from RA and start tearing the engine apart myself. If it takes me a week or two, I don't care - just don't feel that the whole job is worth more than a grand.
Old Feb 27, 2019 | 12:57 PM
CollieRover's Avatar
Time is really the biggest factor. I'd recommend a Fel-Pro Head Gasket kit though. The cheap valve cover gaskets are unnecessarily difficult to install, and you get a better head gasket.
Old Feb 27, 2019 | 01:44 PM
I have yet to mill a set of heads. I check them with a light and a straight edge. Simple.
If they are shot, a junkyard pair of heads does wonders for less than $100.
LolisDisco
Feb 18, 2014 10:10 PM
town10
Sep 17, 2012 12:44 PM
wiltone
Aug 12, 2011 11:40 AM
dillhole
Dec 1, 2009 09:00 AM
avking
Mar 11, 2009 06:28 PM
