Leaking Coolant Pump
Old Jul 20, 2021 | 04:09 PM
robert.juric's Avatar
Default Leaking Coolant Pump
Anyone know what this hole might be? I wipe it and I see more green show up.
Old Jul 20, 2021 | 04:21 PM
redwhitekat's Avatar
if it’s on the water pump it’s called the weeping hole. Change pump it’s telling you.
Old Jul 20, 2021 | 04:23 PM
That’s really a thing?? What’s it’s purpose?
Old Jul 20, 2021 | 05:43 PM
Extinct's Avatar
There is a seal behind the impeller in the water pump, when the bearings wear out the seal fails and coolant gets in the bearings. The weep hole allows the coolant to migrate out and provides an indication that the water pump bearings are worn out and the seal has failed. Your pump will eat itself inside of 2 weeks if you drive it daily.
Old Jul 21, 2021 | 07:10 AM
Dang, I made a big drive up to NC last week and noticed a large coolant loss on the first startup after making it home. I'm glad I got home without incident. Would this weep hole also allow air into the system? I've been battling waterfall for a few months and could never find the source.
I just replaced that pump almost 25k miles ago. Seems like a short lifespan to me. Does brand matter? If its going to die I'll just get the cheapest one. I found a big range from a $40 Europarts on Amazon to a $150 Airtex at AtlanticBritish.
Old Jul 21, 2021 | 08:11 AM
jastutte's Avatar
the Airtex have a pretty good reputation.
i've had their water pump on one of my '04s for several years now.
what brand did you use last time?
Old Jul 21, 2021 | 08:21 AM
I don't recall exactly, it was likely the Proline part from AtlanticBritish. I replaced it when I did my HG job about 4 years ago at 170k miles. I'm sitting at about 193k miles now.
Old Jul 21, 2021 | 01:12 PM
I purchased an Airtex pump from RockAuto for about half of RN or AB.
Old Jul 21, 2021 | 05:54 PM
Extinct's Avatar
It pulled air in because it pushed coolant out.
larson3000
Mar 23, 2010 06:19 PM
asikuy
Mar 5, 2009 06:57 PM
theworks001
Nov 13, 2008 08:19 PM
SurfingRover
Mar 12, 2008 06:47 PM
dammad
Jun 17, 2007 09:14 PM
