leaking raiator fluid
Old Sep 19, 2009 | 05:52 AM
midessa7's Avatar
Default leaking raiator fluid
Hi everyone, the problem that I have is I am leaking radiator fluid from the backside of the engine, can't quite put a finger on the exact spot tough to see. I am going to guess that it is the head gaskets. Some questions that I have though are that there is no over heating and radiator fluid has not mixed with the oil YET. I also noticed tiny air bubbles coming from the spark plug closest to the driver. Wouldn't a blown head gasket be losing compression and actually making a hissing sound.???
Thanks , midessa7
2000 DII
98,500mi
Old Sep 19, 2009 | 09:47 AM
StevenDiscoII's Avatar
Yep, that is leaking head gaskets. Time for an overhaul.
Old Sep 19, 2009 | 10:17 AM
kenk's Avatar
Could also be the intake gasket. Thats a common spot for them to leak.
What do you mean by tiny air bubbles by the spark plug? Is it leaking into the spark plug well?
Old Sep 19, 2009 | 10:22 AM
Will you be doing the head gaskets or a shop?
Old Sep 19, 2009 | 11:33 AM
blcp86's Avatar
I think I'm having the same problem, noticed lately ive been running a little low in the coolant reservoir...looked under her and noticed that there is a leak under there, but not exactly sure where its at, it is dripping down on the front axle, dead center...if it is my heads, how much am i looking at to fix? shop or diy job?
Old Sep 19, 2009 | 12:02 PM
Fill your coolant bottle full, to the lid, every morning before heading out and Have some one check this ASAP.
Old Sep 19, 2009 | 05:50 PM
midessa7's Avatar
I fill it everyday. I will not be doing the work, I'm getting a few quotes. As for the bubbles it's just like I said, I saw a few tiny bubbles coming from the last spark plug closest to to driver while the truck was running, strange I know. I love the truck so I will be getting the work done. I'll let you know how it turns out.
Thanks, midessa7
Old Sep 19, 2009 | 08:12 PM
Head gasket it them because of the bubbles.
$1400 to $1600 plus head work if needed. Make sure to change your plug wires, 8 mm Magnacor's, update your upper radiator hoe to the newer design with the bleed screw in the black plastic tee and install a new t/stat.
rally1
Feb 22, 2022 06:22 AM
leddifer
17
Mar 23, 2016 01:56 PM
blaze98
Sep 23, 2010 05:49 PM
atxrover
Aug 24, 2010 08:06 PM
sfxgamer
Nov 1, 2007 01:42 PM
