leaking rear axle
Old Nov 19, 2006 | 11:39 AM
Tanrover's Avatar
Default leaking rear axle
Hello all !
I'm new to land rovers, I just purchased a 2000 discovery!! I replaced pads and rotors and found a leaky rear axle spindle . I pulled it out, but wondered if it can be rebuilt (bearings and seals) or if I just replace the whole hub.??? I also replaced dif. and transmission fluid with synthetic, hope that was a good idea? It has 73000 miles on it. I hope someone can help!!! thanks ..
Old Nov 19, 2006 | 03:28 PM
Default RE: leaking rear axle
No, you will have to replace the hub.
Mike
Old Nov 29, 2006 | 11:58 PM
01 Discovery's Avatar
3rd Gear
Mike
I just took my 01 Discovery in for inspection today. Two major issues, brakes need to be redone and also I have a leaky seal on the hub assembly. Two questions for you, #1 I had the dealer replace the rear rotors 14000 miles ago, now they need to be replaced, is that possible or were new ones never put on? Secondly, is it possible to replace the seal (Atlantic British said it was an o ring) or do I need a hub assembly as the dealer says?
Thanks
Old Nov 30, 2006 | 11:23 AM
Only the D1 can have the seal replace, D2's get new hubs. Don't let them talk you into new rotors, they shouldn't be needed at this time.
Mike
Mike
cationmoted
Oct 19, 2012 07:39 AM
treant985
Aug 5, 2012 06:23 PM
dilbertland
Feb 25, 2012 06:04 PM
tsuami1
Jul 3, 2010 01:52 PM
Disrover
Aug 21, 2009 09:47 PM
