LEAKING! Whole front of headliner is soaked...
Old Dec 9, 2018 | 04:51 PM
ctfulmer's Avatar
Question LEAKING! Whole front of headliner is soaked...
I am trying to find the source and fix whatever is causing the leaking in my 2004 Disco II.
It does have sunroofs but isnt wet around them at all.
I noticed when i got it, the driver side exterior panel was pealing up, and that does seem to be where the bulk of the water is pooled up and dripping.
Just seeing if there is anywhere else anyone may suggest i look.
It doesnt leak when it just rains and stops, but when there is heavy rain it is like a sponge that gets too full.
Any advice or help is appreciated!
Old Dec 9, 2018 | 07:53 PM
Dave03S's Avatar
Possibly the windshield wasn't installed properly, note where I had to add some clear RTV in the top drivers corner, a common fail point.
Old Dec 9, 2018 | 10:10 PM
Papag1313's Avatar
I had that same problem.... Ended up removing the windshield and finding that the previous "repair" was very poorly done leaving gaps for H2O. There was some surface rust in the corners that had to be fixed, too.
Ended up replacing the windshield for under 500 buck.
No problems since then!
Would also recommend that you caulk your sunroofs closed. Otherwise you will be dealing with leaky drain tubes later on.
DiscoBuckeye
Dec 14, 2018 08:37 PM
JoshLikesToMakeStuff
Jul 14, 2018 06:54 AM
MC04DII
Feb 6, 2013 11:32 PM
expedio2005
Jun 13, 2012 11:21 PM
jdelp
Aug 16, 2007 03:00 PM
