Leaky oil cooling couplings.
Old Aug 23, 2009 | 11:58 AM
lipadj46's Avatar
Default Leaky oil cooling couplings.
I'm getting PAS fluid and now a little ATF leaking from up front by my oil cooler. I'm assuming I have to go and replace the hoses or some o'rings. I have not consulted the rave-cd yet but does anyone replaced these fittings before? Do you have to pull the whole radiator out?
Old Aug 23, 2009 | 12:28 PM
You should just beable to loosen the lines and replace the O-rings.
Inspect the lines really well as it is common for them to rust and get pin hole's which then leak.
Old Aug 23, 2009 | 01:57 PM
lipadj46's Avatar
I will have to take another look. I replaced the o'ring on the PAS pump side but I can't even see the fitting nuts on the oil cooler side of things.
cmb6s
May 7, 2019 09:25 PM
FlyingZebra34
Apr 18, 2014 02:00 PM
hh65flyer
May 13, 2013 06:59 AM
oilspotLR
Off Topic
May 29, 2012 04:44 PM
DarylJ
Apr 14, 2011 09:11 PM
