Lift Kit: Can I remove passenger front shock tower WITHOUT removing expansion tank?
Old Jan 26, 2015 | 11:23 PM
joyntanovich's Avatar
Default Lift Kit: Can I remove passenger front shock tower WITHOUT removing expansion tank?
Hey there....
Is there any way to remove the passenger side shock tower (2004 DII) without having to remove the expansion tank, and re-bleed the cooling system?
I am installing a new OME kit, and that tank is being a pain.
Any suggestions greatly appreciated, already WAY over time allocated to this project (that's part of the love, right?)
thanks,
CJ
Old Jan 27, 2015 | 01:53 AM
bmeier's Avatar
Just pop it loose to get at those two bolts. Once loose you'll have room. You don't have to drain it or remove any lines.
Old Jan 27, 2015 | 04:30 AM
drowssap's Avatar
this true
Old Jan 27, 2015 | 09:01 AM
agthird's Avatar
just dont snap the bottom nipple off the expansion tank when you remove it.....
Old Jan 27, 2015 | 12:15 PM
coors's Avatar
Originally Posted by joyntanovich
Hey there....
thanks,
CJ
Yeah, no need to drain the cooling system. Just lift the X-tank out of its mounting and swing it off to the side. It literally pulls straight up and out.
Refer to the picture below. Gently lift up the front of the tank and slide it forward.
Old Jan 27, 2015 | 10:28 PM
Got it. thanks so much!
fishEH
Jun 7, 2015 06:42 PM
RezzaHD
Mar 5, 2013 09:50 PM
nevada ben
Jul 17, 2011 09:38 AM
thehun
Jun 2, 2011 08:40 PM
