WHICH Lift Kit to use? ~ Disco 2 (and D1, I suppose)
Old May 28, 2020 | 06:11 PM
  #21
zski128's Avatar
Also guaranteed on 2+ lifts your front drive shaft is going to get eaten by the support bar under it when off road and flexing!!
I thought that might be the case. I am going 2” but after I removed the engine from my parts truck the front driveshaft is about 1 1/2” from the cross member. Maybe it can be relocated a little further back on the frame? Seems like it might be important like keeping the frame rails from spreading overtime.
Old May 28, 2020 | 08:57 PM
  #22
Best4x4's Avatar
I’ve had em off 6+ years. You can add a spacer, but you’ll just drag that support along the trail. The TC support is only like 1.5ft back from the one in question.
Old May 28, 2020 | 10:35 PM
  #23
Dave03S's Avatar
Again that depends on if you plan to fully flex, I've never had a problem with a standard size (lucky 8) drive shaft and the cross bar in place but I don't fully flex. 2" lift..
jasonguinn
Feb 10, 2020 07:20 PM
LRlax11
Sep 12, 2014 11:35 AM
demonlarry
Dec 2, 2010 09:44 PM
demonlarry
Feb 18, 2010 11:14 PM
dynomite
Oct 3, 2009 09:07 AM
