Lifter
Old Aug 15, 2013 | 04:20 PM
Kreen is an aggressive solvent cleaner made for industrial engines by Kano Labs. Not really sold for DIY for on the road vehicle use. Could be it will solvent enouigh that you should take off oil pan and clean out pickup after a short use of it. Some say it will make things clean as a whistle, but all the internal sludge coating has to go somewhere.
Also, you have to consider if the solvent will play nice with gaskets and seals. Guys used to dump in a few quarts of Berrymans carb and parts cleaner, but you need to be prepared to do a rear main seal....
Sounds like my kind of snake oil.....
Now the slower proiducts like BG and such might also be a selection.
Old Aug 15, 2013 | 05:46 PM
DISCO JAK's Avatar
Originally Posted by Disco Mike
If you want to get rid of your noise, read the thread I suggested and if mechanical, start actually checking the engine out first the pump then the valve train, don't believe everybody you bump into in the parking lot, won't get you anywhere.
I didn't say I "believed" anyone. I said that's what he told me he used. I also in turn said I wasn't a fan of putting anything in my engine oil.
Old Aug 15, 2013 | 09:34 PM
This is good.
Let me know if I can help you.
Old Aug 16, 2013 | 05:43 AM
drowssap's Avatar
great care MUST be taken when choosing any of these product, you want something that will dissolve the sludge, not dislodge it.
A lot of these product are strong enough to dislodge the sludge but not dissolve it. This will lead to all kinds of problem be cause the dislodges pieces never get to the filter the get stuck in oil gallerys and oil pump pickup.
Old Aug 16, 2013 | 09:07 AM
I would wonder how long the solvent + gunk stays in suspension, before some of it evaporates, and the material re-deposits ?
tunernewb92
Oct 20, 2009 07:15 PM
Evergreen Bob
May 28, 2009 08:23 AM
howellja
Jan 1, 2008 06:57 AM
gsxrgessler
Nov 3, 2007 04:03 PM
2k2wranglerx
Jun 30, 2006 09:44 AM
