Lifter oil hole
Old Apr 23, 2014 | 09:44 AM
NoBama316's Avatar
Default Lifter oil hole
Does it matter which way the lifter/tappet oiling hole is facing when installed? I know there is a top/bottom difference but which way should the hole itself face? Thanks
Old Apr 23, 2014 | 10:15 AM
jafir's Avatar
The lifters rotate as the cam lifts them, so it won't matter as they will not be in the same place when you are done.
(or at least they SHOULD rotate, if they have worn in correctly).
Old Apr 23, 2014 | 10:19 AM
NoBama316's Avatar
That's what I thought because several of them were in different positions when I took them out to clean.
Thanks
tdmadlem
May 21, 2015 06:09 AM
JustinIISEries
Dec 25, 2014 07:21 PM
audiS4S6
May 6, 2010 12:14 PM
Disco Den
Mar 14, 2010 08:45 PM
2k2wranglerx
Jun 30, 2006 09:44 AM
