Light problem
Old Jan 21, 2016 | 05:45 PM
Lone Wolf's Avatar
4wd High
Default Light problem
This may have been addressed before but since I'm new as of today....
I just bought a 2000 Discovery II and have a light problem that someone may know about.
Turning the headlight switch to position 1 turns on parking lights and markers along with dashboard lights. Turn to position 2 and the headlights come on but all the rest go off.
Anyone have any ideas on what is causing this?
Old Jan 21, 2016 | 06:09 PM
coors's Avatar
There's either a fault with the contacts in your headlight switch (remediation- replace the stalk) or there is a fault in grounding circuit. Based off the symptoms you described above I would cautiously, but confidently gamble on a faulty stalk.
Does this happen all the time or just in the bitter cold?
Old Jan 21, 2016 | 06:59 PM
Volunteer Rover's Avatar
got the same problem and it's all the time hot or cold
Old Jan 21, 2016 | 07:45 PM
abran's Avatar
Dis assemble the stalk and clean contacts, re assemble and test.
Old Jan 21, 2016 | 07:55 PM
number9's Avatar
Forum search function works fairly well and you should find previously recommended stalk clearing procedure.
Old Jan 21, 2016 | 08:03 PM
Lone Wolf's Avatar
4wd High
I couldn't tell you whether hot or cold since I just got it and I'm in MT and it's still winter.
I'll give cleaning the stalk a try.
Thanks for the quick responses.
Old Jan 21, 2016 | 08:29 PM
Lone Wolf's Avatar
4wd High
And thanks for the search suggestion. I found a thread that describes the same issue.
Old Apr 18, 2016 | 06:10 PM
sayeedA's Avatar
Lone Wolf - I have the same problem. its been there for a while and I kind of let it be as it was not bothering me.
Have you solved your problem? how?
Thanks
Old Apr 19, 2016 | 06:11 AM
Lone Wolf's Avatar
4wd High
Thanks
I originally took the stalk off and cleaned the contacts as suggested in other threads but that only lasted about 2 weeks. I found a new stalk on Amazon for about $50 (US) and replaced it. No problems since.
Fredzzz
Oct 11, 2013 11:39 AM
XxRoverAllOverxX
Mar 23, 2012 04:49 AM
marlymarl
May 28, 2011 10:34 PM
