Limp mode problems
Old Sep 15, 2017 | 01:17 PM
OffroadFrance's Avatar
Originally Posted by mln01
The RAVE lists seven faults that can trigger limp home mode. Why not get the codes read and act on what the codes indicate instead of guessing?
X1 ......... defo agree.
Old Sep 15, 2017 | 03:21 PM
number9's Avatar
Originally Posted by James Weishaar Jr.
What is RAVE?
Download a free copy of the DII RAVE Workshop Manual here.
Get a PDF copy of the WM manual from the link above. Your first two codes are trans related.
Old Sep 16, 2017 | 09:02 AM
James Weishaar Jr.'s Avatar
MAF looks ok. a little dusty. wiped off the dust are you supposed to spray it with something?
added Lucas trans additives to trans. we will see what happens in 50 - 100 miles.
replaced the fluid in t case.
Old Sep 16, 2017 | 09:37 AM
JUKE179r's Avatar
Spray the MAF sensor element with short burts from a can of MAF cleaner. *DO NOT TOUCH OR WIPE SENSOR ELEMENT!
I get a scribe and pull out plastic intake screen, circular metal spring and the metal mesh screen. Then I wipe all these parts clean with a rag and then reinstall.
Old Sep 16, 2017 | 09:41 AM
mln01's Avatar
Plus be sure to clean the MAF only when the unit is stone cold. And then be sure the cleaner has evaporated fully before starting the truck.
Old Sep 19, 2017 | 09:30 AM
OK, cleaned the maf early in the morning when it was nice and cold. let it dry well. put it back together. tried to go for a test drive and nothing. no movement in any gear forward or reverse, high or low, manual or auto. I am really starting to think torque converter. as i stated earlier, the previous trans was doing the same thing. when i switched it out i used the original torque converter. I have the same issues and they seem to be getting worse.
Old Dec 12, 2024 | 07:26 AM
BlueManChu's Avatar
3rd Gear
What ever happened with this?
freeski27
Jan 7, 2014 11:57 AM
cedward
Jan 3, 2011 04:39 PM
Rickey_240
Apr 2, 2010 05:33 PM
vanhorn2dallas
Mar 15, 2010 11:29 PM
xb70valkarye
Feb 2, 2010 10:13 PM
