coolant hose connector
Old Mar 26, 2012 | 09:12 PM
rlcj_racing's Avatar
6th Gear
Default coolant hose connector
I need to replace my three way rad. coolant hose connector. I found a couple universal one's but I'm not exactly sure of the hose diameter. Anyone know right off hand?
Thanks
Old Mar 26, 2012 | 10:39 PM
jafir's Avatar
You are better off replacing the hose. There is a bleeder in the T. If the bleeder isn't there but in the hose, then it's an old hose that needs replaced anyway. The old style hose is likely to blow and cause you to over heat.
Old Mar 27, 2012 | 06:38 AM
No universal hoses on a Disco unless you want over heat problems because you can't bleed the system properly.
Also plan on changing out your old t/stat if it hasn't been done in the last 60,000 miles.
Old Mar 27, 2012 | 12:19 PM
6th Gear
I didn't know about the bleeder. Thanks for clueing me in. I saw it in the manual & was a bit confused because mine doesn't have one in the hose OR the 'T'!
Luckily I haven't had any overheating issues. The 'T' is corroded & partially broken @ one end.
I found & ordered the whole upper hose ***. w/the bleeder in the 'T' from RoversNorth this morning. I sure couldn't find it anywhere around town.
I guess I should of ordered a thermostat also.
By thermostat do you mean the whole housing assembley?
Thanks
D2 2003
Nov 7, 2017 07:41 AM
Dpavelock
Jan 3, 2015 12:03 PM
slanginsanjuan
Apr 2, 2012 06:56 PM
G Reeves
Feb 23, 2012 04:46 AM
kpl1228
Jun 21, 2011 10:12 PM
