The list goes on... My goodness.
Old Feb 18, 2010 | 01:56 AM
skatelove303's Avatar
Default The list goes on... My goodness.
So heres the list of things wrong with my rover.
Head gasket going out.
Power steering leaking.
Brake fluid leaking on my front passenger side wheel.
A hole in my Cat... blowing out steam from the head gasket... Great!
Either a faulty transmission or transfer case.
I dont even know where to start!
Old Feb 18, 2010 | 04:34 AM
d2luvr's Avatar
One step at a time. What sense is driving if you can't stop. My 2 cents:
1 brakes
2 head gaskets
3 tranny/tc
4 PS
5 Cats, unless you have an inspection due sooner.
By the way have you been over Rollins Pass or Mammoth Gorge? That used to be fun. Its been 25 years since I was up there. I am trying to get some time off so that I can bring the family out to see where I grew up.
Old Feb 18, 2010 | 08:41 AM
hilltoppersx's Avatar
you can fix everything in a weekend. start by getting the rave manual from D2luvr's signature. then get the head gasket kit from British Atlantic. http://www.roverparts.com/Parts/STC4082HBK.cfm also get new head bolts http://www.roverparts.com/Parts/9224.cfm
trace the power steering and brake fluid leaks fix accordingly.
drain and inspect fluids in TC and tranny. check for signs of metal. The transmissions are usually very strong in our trucks so my bet is a bearing or something in the transfer case. and finally your exhaust can be fixed at an exhaust shop, have them cut out the old cat and replace it with a new one. no need to buy a whole exhaust system.
Old Feb 18, 2010 | 08:44 AM
lipadj46's Avatar
if you don'y owe money on it sell it and buy another one
Old Feb 18, 2010 | 08:48 AM
okdiscoguy's Avatar
Your list isn't too bad. Head gasket will take the longest.
What is your tranny/ X-fer case doing?
Get a rebuild kit and pull both front calipers. They are really easy to re-buid.
Did you go to the dealer and have an inspection or something? (ha ha)
Old Feb 18, 2010 | 03:11 PM
AK Rover's Avatar
If your leaking brake fluid you're not going to have brakes for long. Park the truck until you get the brakes and head gaskets fixed. This is all stuff that should have been fixed before you spent the money on a lift and tires.
Have you even done the 60K service yet?
Old Feb 21, 2010 | 12:43 AM
Well i didnt need head gaskets at the time of the lift purchase. it didnt need anything. Or brakes. How much would doing head gaskets cost? Ive now lost heat.
marlymarl
Apr 21, 2012 12:49 PM
Discolife
Nov 23, 2011 01:13 PM
elboy0712
Feb 7, 2010 02:42 PM
luxury1
Feb 4, 2009 06:51 PM
