Little bit of help needed if you can
Old Dec 13, 2015 | 12:07 AM
  #31
number9's Avatar
Default Understanding
PMF, DQ or not giving enough relevant info. It's only a machine not a first born child.
Old Dec 13, 2015 | 02:11 AM
  #32
zeroone's Avatar
Dick.
Old Dec 13, 2015 | 06:29 AM
  #33
dgi 07's Avatar
Find out how high it goes. I'll hit 204. Not happy with it, but it's something that's endemic.
Old Dec 13, 2015 | 06:55 AM
  #34
JAIMELU's Avatar
Originally Posted by zeroone
Here is the original thread,
https://landroverforums.com/forum/di...-advice-76298/
I've bled the snot out of this thing, replaced the non-functioning condensor fan. I even went as far as to replace the thermostat just because. Auxiliary fan comes on at 210* at idle. Why is it hitting 210 with a 180 stat? It hit 215 before I brought the revs to 1500, at that time the temps immediately dropped, fast.
I'm deathly afraid to drive it for fear of causing unnecessary damage.
Little more backround, waterpump, fan clutch, and radiator are all around 2 years old in January.
zeroone, i guess is a disco ,v8 4.0, what kind of milage you have on it, if its over 150k
probably you have clogged block or head water passages, to fix that , replace head gaskets and it´l be ok, cheaper knock off the thermostat, will cost you more on petrol. longer time to warm up.
Old Dec 13, 2015 | 10:19 AM
  #35
zeroone's Avatar
147k. Heads where just done, coolant system is new-ish save for the burp tank and heater core.
I'll just drive it once in a while until I figure out what it's deal is. It's perplexing to me. With my luck, my 1.5 year old rad is clogged.
Old Dec 13, 2015 | 10:15 PM
  #36
chubbs878's Avatar
I have been keeping my control unit blasting at one notch under max speed, automatic, and recirculate mode all engaged. This helps to keep the temps on mine somewhat evened out between 196 and 201. Sometimes cruising the highway, it will get down to 194 and have seen it down to 190 a few times. 196-198 the other 75 percent of the time. I don't get how it can be 194 or 198 at same speed, ambient temp, etc. when I start it cold it will idle at 194 and stay there. Start moving and engine temps do whatever they want from there. I'm going to order a real thermostat and other gadgets to try something new.
Old Dec 14, 2015 | 06:27 AM
  #37
zeroone's Avatar
Been doing the same, except, mine will not maintain temperature at idle as far as I can tell. If the auxiliary fan comes on I will shut it off.
Drove it all weekend. Never let it idle, never saw greater than 203 climbing a very steep hillike at 25-30mph. I was panicking... lol
Old Dec 14, 2015 | 08:30 AM
  #38
dgi 07's Avatar
Pressure test it.
Old Dec 14, 2015 | 11:28 AM
  #39
zeroone's Avatar
I'm not losing coolant.
OffroadFrance
Off Topic
Apr 12, 2014 10:50 AM
honda50r
Dec 9, 2013 09:53 PM
Spencerfitch
Sep 2, 2010 08:51 PM
Dimitri_g101
Freelander
Feb 5, 2010 01:07 PM
chakadog
Jul 11, 2007 11:03 AM
