Little bolt in the flex plate
Old Mar 30, 2021 | 06:58 PM
zacharyz28's Avatar
Default Little bolt in the flex plate
Just finished getting the transmission out of my 2000 Disco and when I took the torque converter bolts out I found a single strange torx bolt in the fly wheel. I saw it first through the drivers side oil pan hole and I removed it thinking it was a torque converter bolt (first time here) but there was only one. Now that I have the thing apart I can't find that bolt but I have no idea what it is for. Does anyone know?
Thanks
Old Mar 31, 2021 | 02:49 PM
zacharyz28's Avatar
If it helps anyone help me I am pretty sure it came out of one of these thread holes on the outer edge of the flex plate. The only thing I can think of is it was for engine balance????
Thanks
Old Mar 31, 2021 | 06:40 PM
zski128's Avatar
Yes I am fairly certain that was weight added to balance the flywheel. The factory will drill a hole to subtract weight and tap a hole to add a weight.
Old Mar 31, 2021 | 09:22 PM
mollusc's Avatar
Seconding that. It's a balance weight. You're going to run into a lot of vibration and potential bearing failures without it.
Old Mar 31, 2021 | 09:30 PM
zacharyz28's Avatar
Found it! Now I just need to figure out where it came from. Hopefully there is a dirt ring or something. Just weird that they use a bolt to balance it.
Old Mar 31, 2021 | 11:10 PM
mollusc's Avatar
Seems just about the best way to do it to me. Milling away material has a number of risks, so attaching fixed weights at a variety of possible points offers a lot of safe flexibility.
Hope you're able to identify the correct place to put it back. Use threadlock when you do reinstall it.
Old Apr 1, 2021 | 04:55 PM
zacharyz28's Avatar
Well I can't figure out which hole it came from. I suppose if the engine is internally balanced I could just get the fly wheel re-balanced . Does anyone know how the engine is balanced?
Thanks
bballjames
Nov 4, 2013 02:17 PM
Savannah Buzz
Jul 6, 2013 05:22 PM
weepit
Apr 7, 2013 08:35 PM
kraelo
Apr 1, 2008 12:02 AM
JEFF
Apr 19, 2007 09:47 PM
