Long crack in windshield
So I got the truck about 3 mo ago with a long crack in the windshield. Thinking about replacing it before NJ winter. It currently has a heated windshield, I know those are very expensive, is it worth the money to get a heated replacement or just go standard? Also how much is the growing rate for a new windshield (heated or non heated)?
Thanks
Thanks
Check to see if your insurance company will cover it. I went thru this last year and insisted on an OEM replacement that was heated. Had it done by safelite. The big issue are the vertical pillars on each side of the windshield. LR uses crappy clips and the break easily. AB usually has the pillars in stock.
I believe NJ has no deductable for windshield.
It is really a shame when the windshield gets hit by a rock right after you buy a car.
Thanks
audiS4S6
Apr 18, 2010 11:02 PM
