Long term fuel trim reset, Concerns with Key
Old Aug 28, 2019 | 02:50 PM
DodyDisco's Avatar
Default Long term fuel trim reset, Concerns with Key
Can anyone tell me If i remove the battery and connect the leads together to drain the Computers down/reset fuel trims Will i have issues with restarting.
I have only the physical key at the moment, I don't have the remote/plib thing Will my car immobilize or any other funkyness after a reset ?
Thanks.
Update
Battery disconnect didnt screw me/no crazy immobilizer business with me only having the physical key no remote, Also nothing i could do would reset long term fuel trim, Although after a 30 mile drive on top of my new fuel pump they dropped back down to a normal level.
Old Aug 28, 2019 | 05:01 PM
Ben Matheson's Avatar
I've has my battery disconnected several times and it had no effect on the keyfob
Old Aug 28, 2019 | 05:36 PM
DodyDisco's Avatar
Not so much disconnecting the battery that worries me, Draining the CPU's down has me wondering.
Old Aug 28, 2019 | 05:39 PM
My ltft reset just swapping a battery. No such thing as draining the CPU. Only thing that isn't stored in non powered memory is radio presets and AC default settings
Old Aug 28, 2019 | 05:45 PM
Llamasayswhat's Avatar
Make sure the doors are all unlocked and alarm is not active before pulling the battery.
Also, I don't think a battery reset clears out your fuel trims on the D2. It is stored in long term memory
Old Aug 28, 2019 | 05:52 PM
DodyDisco's Avatar
Guess ill do a bit of an experiment. Replacing my fuel pump so Im disconnecting the battery anyhow. Ill check the LTFT after Im finished. If it has not reset, Ill find a plan B or try the leads together for a bit.
JHDisco2
Oct 6, 2015 08:41 PM
JPSpen
Oct 9, 2012 03:41 PM
liPPy
Dec 30, 2010 02:49 PM
bangkuaidiscovery04
Oct 12, 2010 05:10 AM
bigugly82
Jan 10, 2008 03:34 PM
