Looking for Advice on P1172 and P1175 Codes
Old Jul 12, 2016 | 10:52 PM
  #41
discorey's Avatar
Originally Posted by disc oh no
I hope that's all it is. It's always nice when you can fix things without spending money on parts.
Seriously. I'm hoping so much that I can avoid dropping $120 on a new MAF and $174 on a new IACV. I'd rather be spending money on finishing my suspension buildup and tools.
Old Jul 13, 2016 | 06:09 AM
  #42
disc oh no's Avatar
From your description, it doesn't sound like a MAF sensor. Usually that wouldn't cause a problem on startup only.
Old Jul 13, 2016 | 07:02 AM
  #43
DiscoBuckeye's Avatar
I know a few guys that have used the cheap MAF from Ebay or Amazon $28-$35.
Even if just to check.
Old Jan 26, 2017 | 10:29 PM
  #44
KingKoopa's Avatar
According to some reading, "additive injector adaptive fueling" is done at idle. Multiplication is done at all engine speeds.
This makes sense as the codes only pup up at idle.
What I don't understand is whether Fuel trim and injector adaptive fueling are the same thing or correlated. For instance, a negative fuel trim means that the computer is pulling fuel to adjust for a rich condition. So by these definitions, does "rich limit exceeded" mean that the computer has told the injectors to shorten their pulse widths as much as it possibly can bit the o2's are still reporting a rich condition? Or that the computer has cranked the injectors on to the max, and as a result has over compensated and caused the rich condition?
​​​​​is short term fuel trim the same thing as additive injector adaptation? Two names for the same data?
srockrae
Jan 31, 2013 07:44 AM
ChefGabe
Jan 26, 2013 09:35 PM
ChefGabe
Feb 1, 2012 09:26 PM
savageracer2008
May 18, 2011 07:15 AM
seamuspg
Dec 13, 2009 09:10 AM
