Looking to do the motor mounts soon
Old Sep 27, 2012 | 07:44 PM
Snafu / Disco Fries's Avatar
Default Looking to do the motor mounts soon
I have had a bit of a rumble/rattle when starting and at certain rpms for a while. While doing work last time, I noticed the mounts looked worn, and the driver side might be split. I think this is also making the tick more audiable, as there is a slight leak by the bottom of the header I noticed when I did a Seafoam treatment a few months back.
So, before winter, I would like to get a new set in. A few questions though.
1. Would this be easiest to do with the front wheels on rhino ramps and then jacking the engine up with a floor jack/2x4's? I'm asking for both safety (I would rather not jack the truck and then jack the engine) and ease of use (like is there room enough to do it with the truck on it's wheels).
2. For a guy with big paws, is this going to be near impossible? The write ups I saw mentioned some tough spots. It took me half a day to get the top trans cooler line off and on the trans...not looking to do something like that again!
3. Any other tips and tricks for those that have done this? Useful tools, etc?
Thanks in advance. This and the RAVE are what I'm basing my work on https://landroverforums.com/forum/di...nts-how-30194/
Old Sep 27, 2012 | 08:05 PM
Rovin4life's Avatar
Motor mounts will cause clunking and pulling on acceleration and decel. I bet the rattle is from the exhaust making noise. You might have a backed out stud on the exhaust manifold.
Old Sep 27, 2012 | 08:32 PM
If your drivers side is split, it is time for them even if they are not causing your noise.
Do you wheel hard enough to switch to the HD all metal motor mounts or will you stay with the standard rubber?
Old Sep 28, 2012 | 06:01 AM
drowssap's Avatar
to answer your question put the truck on ramps then jack the motor, it will make your life easier.
Old Sep 28, 2012 | 07:47 AM
jeffh's Avatar
yea jack it up... then jack the engine...it is really not that difficult. As long as the bolts are not seized. I would start hitting the bolts with PB Blaster a few days prior to starting this adventure. I got lucky. took me all of an hour, start to finish. I went with the standard Rubber mounts kinda wish I had upgraded to the more extreme mounts available. Oh remember to disconnect the air box to the MAF I forgot and jacked the engine to the point of cracking the snap lock connector...
Old Sep 28, 2012 | 04:58 PM
I don't think I want to go HD, unless someone tells me there are good reasons. I use this for ski trips, mountain biking, etc. some light off road use too. Nothing extreme. I went to a HD style in a car I would take to the track, and it caused much more vibration to be felt in the cabin during normal driving.
Old Sep 28, 2012 | 05:25 PM
Based on what your diving is, the HD mounts would be over kill.
vandev
Jun 16, 2025 07:54 AM
FlyingZebra34
May 3, 2012 09:17 AM
Willie00d2
Feb 17, 2010 09:49 AM
btbaus
Nov 16, 2009 01:40 PM
aublec22
Feb 7, 2008 06:09 PM
