Looking to purchase
Old Jan 23, 2014 | 07:44 AM
Zorm's Avatar
Default Looking to purchase
My son is looking at a 2000 Disco and this is in the add "apparently has a transmission front seal leak"
So, keeping the fluid topped off is a must but is this something that can be done at a later date or need to get taken care of right now. I do all my own work and have droped transmissions before, how involved is it in a Rover, can it be done without taking out the engine or is that the prefered method?
thanks for thoughts
Old Jan 23, 2014 | 08:56 AM
SuperBuickGuy's Avatar
generally (though, I've not dropped or pulled a LR motor or trans), it's easier to drop the transmission - there are less fluid-filled lines that can be broken on a transmission.... R&R a transmission is 4-6 hours, R&R a motor is 8
Old Jan 23, 2014 | 01:55 PM
Dan7's Avatar
Remove exhaust + rear driveshaft + tranny mount (while supported by jack). Then bolts at back of bell housing (I think there are 6). After you remove all the wires (sensors), you should be able to wiggle it back on the jack. Of course this is an overly simplified version, so please follow the RAVE, but definitly easier than removing the engine.
disco97
Jul 6, 2007 08:37 PM
chakadog
Apr 10, 2007 11:25 AM
coursesuper
Nov 13, 2006 04:35 PM
Justmealex
Oct 19, 2006 06:45 PM
bigugly82
Oct 2, 2006 01:51 PM
