Looking for some advice!
Old Dec 29, 2009 | 11:17 AM
rekogniz1's Avatar
Default Looking for some advice!
1. Don't know what kind of oil the person prior had been running but just did heads and such and want to go Mobile 1. Good or bad to make a switch so late?
2. I have stock 18" wheels with 255/55/18. What tire perssure do you all use for front and rear or just use MFG reccomended per the door sticker?
Old Dec 29, 2009 | 11:25 AM
lipadj46's Avatar
Switch to mobil 1 5w40 TDT and be done with it. Ignore any slight leaks or weeps for the first couple oil change intervals (at least 5,000 miles and probably more with the TDT oil, though you may want to change your oil filter at 2000 miles for the first OCI as the HDEO will clean up a bit).
Old Dec 29, 2009 | 11:58 AM
salve7's Avatar
I run 40 psi all around and let the front down to 35 if I expect alot of ruts and such.
Old Dec 29, 2009 | 12:11 PM
lipadj46's Avatar
I ran at 40 psi but with the medium OME springs that is a rough ride. So I backed down to 35 and it is still rough. You would probably be fine with OME type springs or air bags to go 40 all around.
Old Dec 29, 2009 | 01:57 PM
Auto Zone has a sale on 5 quarts of any Mobil 1 and a Mobil 1 filter for $29.95, go take advantage of it, use their 301 extra long filter.
roverparty
Jun 14, 2015 03:31 PM
StormTroopa
Aug 9, 2009 05:26 PM
VXdude
Jun 8, 2009 04:19 PM
BlazinBWF
Sep 30, 2006 09:51 PM
dpakman91
Freelander
Mar 14, 2006 04:29 PM
