Loose Cowel/hood for gage cluster??
Old Dec 20, 2017 | 02:35 PM
Fast50's Avatar
Default Loose Cowel/hood for gage cluster??
Does anyone know how to fix a loose cowel/hood cover for the gage cluster on the steering column? Mine is loose and could be pulled off if it wasn’t for the connections on either side. Any help/tips or tricks would be greatly appreciated. Thanks guys
Old Dec 20, 2017 | 02:44 PM
Davis31052's Avatar
Most likely its sun warped. Remove the 2 screws above the steering column surround and take a look.
I'm sure one of the used parts suppliers here can help though.
Old Dec 20, 2017 | 03:03 PM
OverRover's Avatar
Have at it!
Check that the 2 mounting screws haven't broken through the cowl. It's easy to do if someone overtightened the screws.
If so then a screw with a washer will help, or fill the cowl holes with 2 part epoxy and redrill.
Old Dec 20, 2017 | 03:51 PM
mln01's Avatar
I used a couple drywall screws (really) and a couple finishing washers. Looks a little ghetto but it's a 19 year old truck approaching beater status. Lots of things look worse than the two screws no one notices.
Old Dec 20, 2017 | 05:13 PM
dtmbinb's Avatar
Go for the expensive fix and add some black spray paint to the drywall screws and washers! Less noticeable, but It ups the repair price to the $5 range. LOL! Seriously, the screws and washers are the ticket!
Old Dec 21, 2017 | 07:54 AM
Fast50's Avatar
Thanks for the advice guys... I am going to try and tackle it today. ☘️
Old Dec 22, 2017 | 06:55 PM
Charlie_V's Avatar
When you pull the cover off be extra careful. There are two tabs at the front (of vehicle) that engage plastic on the cover. If you break the plastic it is a slow, twisting death for the cover.
huggi
Sep 18, 2016 05:07 PM
hrhoward
Jun 30, 2015 04:27 AM
dpaller
Jun 1, 2013 10:40 PM
twaszak
Nov 3, 2010 11:58 AM
robot808
Nov 18, 2009 11:10 PM
