Losing coolant but the reservoir tank stays full?
Pretty sure I have another blown head gasket because I'm losing a lot of coolant. I'm getting the waterfall behind the dash every few days and have to add several pints of fluid via the bleed screw in the T. However, the reservoir always stays full. Is this an indication of a bad thermostat, or is there another possibility?
Yes, there is absolutely air in the system. That's what is responsible for the waterfall, and that's what I'm displacing when I'm pouring in the coolant. But with the amount of fluid I'm adding the level in the reservoir should be going down a bit, even if there are air pockets still remaining fterwards. But it's not going down at all.
aguison
11-18-2012 05:15 PM
