Losing coolant but the reservoir tank stays full?
Old Jul 27, 2018 | 06:38 PM
mollusc's Avatar
Default Losing coolant but the reservoir tank stays full?
Pretty sure I have another blown head gasket because I'm losing a lot of coolant. I'm getting the waterfall behind the dash every few days and have to add several pints of fluid via the bleed screw in the T. However, the reservoir always stays full. Is this an indication of a bad thermostat, or is there another possibility?
Old Jul 27, 2018 | 07:35 PM
redwhitekat's Avatar
Sounds like air. If your tank is full leave it or try bleeding it properly
Old Jul 27, 2018 | 11:06 PM
mollusc's Avatar
Yes, there is absolutely air in the system. That's what is responsible for the waterfall, and that's what I'm displacing when I'm pouring in the coolant. But with the amount of fluid I'm adding the level in the reservoir should be going down a bit, even if there are air pockets still remaining fterwards. But it's not going down at all.
Old Jul 28, 2018 | 08:48 AM
abran's Avatar
If the system is pressurized from combustion gas in the coolant system then the level might stay higher,but... once it cools you should see a drop in the level.
maybe you have a clogged hose going to/from the tank?
Old Jul 28, 2018 | 08:58 AM
mollusc's Avatar
The system is pressurising and when I fill via the bleed screw it starts to drip from the overflow pipe on the reservoir. I will check the other hoses going to the reservoir though.
Old Jul 28, 2018 | 10:16 AM
Why are you filling it via the bleed screw. Just fill the tank to the cold position bleed it and drive it. Monitor your temps
Old Jul 28, 2018 | 10:24 AM
mollusc's Avatar
The tank is full. The system is not. Adding more to the tank would literally just be pouring it on the ground.
DiscoHan
Sep 16, 2014 11:03 AM
johnnyjohnny
Mar 25, 2013 08:46 PM
JAC
Oct 21, 2009 10:40 PM
bigfun
Dec 13, 2007 04:23 PM
