at a loss after engine swap
Old May 9, 2014 | 12:51 AM
MarkSF's Avatar
Originally Posted by ralphobell
Did you put the grounding strap back on the engine?
My first thought, too.
Old May 9, 2014 | 05:13 AM
drowssap's Avatar
to test the ground, just run a booster/jumper cable from - to the engine, cant get a better ground than that.
Old May 9, 2014 | 07:55 AM
jhk07's Avatar
A 2003 with an original 4.6 ????? really ???
Old May 9, 2014 | 11:59 AM
tuercas viejas's Avatar
Originally Posted by markle0258
Ok guys thanks for the feedback
Jafir. as far as the IVAC connector-not to my knowledge. will check to be certain. also shifter on indicator gauge shows correct gear
Tuercas Viejas. massive imput thank you. have answers to most here, a few i cannot be certian
#1 its a 4.6
#2 original build
#3 the old engine had massive oil leaks with a suspected dropped sleeve, was cheaper to replace.
#4 ECU was flashed and re-calibrated because it was believed to be fried by a incompetent mechanic. factory re calibration. was working great before replacing engine
#5 PCM (power train control module) same as ECU? if so i have a obd2 scanner and the shops got a $8000 scanner not sure specifics on make neither will connect
#6 if PCM is the same as ECU then yes i could access it fine before engine change. (MIL plug)? unsure not the best with acronyms.?
#7 donor engine ran smooth
#8 as far as i know the grounds have been checked not sure if they have been crossed with positive chassis (how to tell).?
#9 looking for a parasitic draw is what we are currently looking for, what are some signs of such.
#10 im afraid your going to have to expand on this question. ( does he have the ability to access the various positive and negative pins in the MIL connector and confirm continuity and good grounds)how to due such? (The equipment he has can he access modes 6 through 10 and use an oscilloscope to access module/sensor wave forms ?) i dont believe this garage has that equipment.
Im sorry i am unable to answer all of these in detail. im not as knowledgeable in electronics as i should be. i am i quick study tho if you can break it down.
thanks for your response
OK we are going to assume all was in good operation before replacement took place but with some reservations.
As pointed out and mentioned by me the primary circuit integrity is the first thing to look for. That includes grounds as mentioned by other contributors.
With a Pro Mechanic helping you, the rule of thumb when you suspect a grounding issue is to obviously check that all grounds have been re-installed correctly. If in doubt you introduce a test ground from engine to chassis, (as mentioned )alternator case to battery negative/ground, body to chassis, chassis to battery ground, and ultimately PCM metal case to a good known ground. Correct these issues and you most likely will correct the M&S illumination /falsh activity.
The PCM is mechanics talk for what you call a computer! Specifically the Powertrain Control Module is what you have had presumably re-flashed at some time in the past.
For it to work correctly the line voltages must be consistent and parasitic draws particularly direct to ground must be eliminated.
The next thing is to lift the underhood fuse box cover and check fuses and relays feeding the PCM circuits. Indeed it doesn't hurt to lift the fuse box and see if the harness hasn't been "pulled" in the in change activity. The same goes for the harness running from PCM to the 02 sensors, crank sensor etc, behind the heads. Both can get damaged in advertantly at socket connectors during a change out.
The inability to access the PCM and other modules is of concern; the MIL connector is mechanics talk for the diagnostic connector. It has contact pins designated for various activities and communication with the modules in the car and other functions. It is essential it has good grounds and feeds to excite the diagnostic tool you are inserting into the connector.
Here's a pin out.
Vehicle OBD II Compatibility
Check to see if you have power and good grounds as refered to in the diagrams.
As a matter of point NEVER disconnect the diagnostic tool when in the middle of a diagnostic scan it can leave any on board module in "la la land" with no communication.
My last comment is that using a good scan tool as a professional will ease repair times. I use an Autologic and a Snappy Verus Pro to access all the modes which a simple scanner won't do. I was hoping your Pro mechanic helper would have access to scan and osciloscope functions as in the Verus tool which helps enormously to identify faults. Modes 9 and 10 will access PCM functiocs and see if the operative who re-flashed the PCM did it right as sometimes even the loss of a few Vin digits can cause the program to drop out when powered down as might have been the case when you changed out the engine.
In the meantime I think your best bet is to go over what you have installed and check ALL your connections and correct that parasitic draw.
Usually in this business its the simple things that cause most of the problems.
Take care and keep us posted on your progression.
T/V
Old May 9, 2014 | 01:39 PM
MarkSF's Avatar
The best way to test the engine ground, is with a multimeter. Select DC volts, and measure between the engine and the body. Get someone to turn over the starter motor, and watch the reading. Anything above 1/2 volt would indicate a resistive connection somewhere.
My Triumph TR8 (Rover 3.5) had 2 volts between the engine and the body when the engine was running! Meaning the alternator was putting out 14V, but the battery wasn't being charged at all. Had a very bad ground strap. Got a brand new one made.
If you have a resistive connection, the voltage across it will be proportional to the current. That's why I suggested measuring while cranking, this is the highest current case.
Old May 9, 2014 | 03:22 PM
RoverMasterTech's Avatar
Don't worry about the grounds right now. It starts, so you have a connection between the BCU and the ECM. So you should have comms on the Diagnostic plug. Alot of scan tools wont connect if they don't get power at the connector. Check fuse 20 under the hood to see if something got messed up and popped it. You need to first get a scan tool to connect to the ECU before you start poking and prodding at things. Don't worry about anything but getting a scan tool to work, otherwise you are wasting time.
Old May 10, 2014 | 10:50 AM
Camtait95's Avatar
What lift would you have to have to tuck some 35 inch mud tires.?
Old May 13, 2014 | 09:44 PM
markle0258's Avatar
4wd High
Ok update here, grounding strap is secure and was tested. all grounds have been tested and have come out to my knowledge as good. What is believed currently is that when the engine was re-installed that a positive wire got grounded out somewhere. Either pinched, or burnt and fused to another wire causing the short. Mechanic is going wire from wire checking.
Believe we are going to try and run a parallel wire to bypass the short to narrow down which one. Any opinions? thanks again for the feedback
rikdburns
Feb 27, 2010 06:37 PM
djessopeng
Dec 27, 2008 09:33 PM
clanceyk
Nov 11, 2008 08:47 AM
ontheroadagain
Mar 27, 2008 08:10 PM
aviat
Feb 21, 2006 12:38 PM
